Problema apertura sketchup
HELLO I HAVE A PROBLEM I CAN NOT OPEN THE FILE OF SKETCHUP 20115 PRO ONCE SAVED
I MUST proceed to RIAVVISO MACHINE OPERATING SYSTEM Winsows 10
Well post the model, here or somewhere where it can be inspected.
I have the problem with all the newly saved files saved on this computer
you can not erase
cassetti.skp (385 KB)
You cannot erase what ?
drawings saved with sketchup and only those with .skp extension do not
open and can not be deleted. To be able to open them and Cancellari must
riavvare the gaming system
thank you
There is nothing wrong with the model. Are you trying to open a version 2017 .skp file with an earlier version of SketchUp ? You would have to open it in version 2017 and then Save As->Save As Type->SketchUp Version 20XX (.Skp)
cassetti.skp (405.3 KB)
the file you just saved with sketchup pro 2015 ways more open and not deleted
So this solved your issues ?
No
when it does not open the file appears written totally abandons string is long. when it should be long
Are you trying to open .skp I another program then sketchup ?The grammar doesnt make much sense…
Maybe writing own language triggers someone who does!
This seems (I’m guessing a bit) like another older thread
which was solved by installing a later maintenance release.
