I CAN’T OPEN ANY RENDERING PROGRAM . EVERY TIME I OPEN SKETCH UP SHOWS ME THIS ERRORS . WHAT CAN I DO ???
No need to yell.
First make sure SketchUp was installed correctly. That requires right clicking on the downloaded installer and choosing Run as administrator. If you didn’t do that, close SketchUp, find the installer and do it. Then if presented with the option, choose Repair.
Then try reinstalling Vray the same way.
And log in to the V-ray website and check that you have the latest version of V-Ray
Thank you very much . I found the problem . Have a nice day
Thank you very much . I found the problem . Have a nice day .
Well, what was the problem?
Здраствуйте. Такая же проблема. Как решить её?
From Google Translate: Hello. Same problem. How to solve it?
What is the problem? Which rendering application? Which version? Which SketchUp version? Have you asked in the V-Ray forums?(if it is V-Ray). What is in the error message you get?
установлены последние версии SketchUp и V-Ray. проблема с dll отсутствие либо не работают.
