Printing to scale "sketchup for schools"
Hello, my name is Carles and I use sketchup for schools. When I print at 1/50 scale the generated pdf is not really well scaled. There is a difference: a 1500 cm line at 1/50 scale is 30 cm but it is really printed with length 29cm.
Is there a way to fix?
Thanks
Are you setting the Camera to Parallel Projection and selecting the appropriate standard view? When you print the resulting PDF are you printing it at actual size or is the print being scaled by Adobe Reader?
Hi @DaveR, thanks to reply.
I use parallel projection and standard view, but the plane is printed in a shop because is DIN-A3. Yes, if I print at home is well scaled. I don’t know how they (shop) print.
Does this mean it’s correctly scaled in your print? If so, the issue is with the shop doing the printing.
What is it you’re modeling and how is it to be used?
We are modelling a house, to print out the plans and then make a model of it
Thanks @DaveR
