Hi, I want to print from sketchup pro a set of house plans on A1 paper (841mm x 594 mm) . This will be at o local printers so I need to save the file on a stick in such a format that they can print to 100:1 scale or I suppose I could print directly from the pc. Can anybody help me with this–quite new to sketchup and an amateur! I cant find a video tutorial that shows how to do this on a pc. Thanks, Nick
Set up scenes in SketchUp to show the views you want, send the file to LayOut and create viewports from the scenes with the scale set as desired. Export a PDF and send or take that to the printer.
Thanks Dave I will try that now–Nick
Ive got a lot to learn-trying to find out what a viewport is ?
Mine is a simple front end and plan, 2 dimensional drawing of a house, before and after
Did you check your PMs?
