Printing to pdf from Layout - HUGE!
I’ve been printing pdf files from Layout for years. Its never been fast, and the files have never been small, but suddenly it’s incredibly slow and the resulting files are enormous! A three-page Layout file (3 x A1 drawings with some textures), when printed this morning the pdf is OVER 200 MEGS!!
and when i run it through a (not very good) online pdf compressor, it reduces by 97.6% !!! its now 4.7Mb.
Mac Os 27.0.1. Sketchup / Layout v. 26.2.242
what is going on here?!
Instead of using a printer driver, have you tried using the built-in PDF Export feature in LayOut?
Yes, and you’re right, its much better!.. But still pretty terrible in my opinion..
74mb Sketchup model, referenced into a 76mb Layout file, using my 2023 iMac with an M3 chip (not a great setup, but not terrible either!
printing to PDF using the print driver - total time 2 minutes 59 seconds to export three pages, making a 100.7 Mb pdf file
Export to PDF using Layout - total time 33 seconds, making a 25 Mb pdf file.
I then compressed them both using PDF24, and the 100 Mb file reduced to 3.7 Mb, while the 25 Mb file reduced to 1 Mb.
This could be a result of the size of the texture files you are using in SketchUp. In the old days SketchUp would cap the size of the image size used on materials. This was updated a few releases back and so this maybe the reason you are seeing such large export sizes.
We made stability changes in 2027.0 to handle this during export along with the upgrade to how we render Vector lines you will most likely have better export times.
Trent
I don’t use a Mac but I would guess that using the printer driver to create PDF files renders your pages mainly as high resolution raster images, perhaps with no compression, whereas the exporter creates a mix of vector, raster and text, reflecting the page contents. Now when you apply an optimiser, it usually applies compression to all images.
Tweaking the PDF exporter settings affects resulting file size and quality. Especially using the default JPEG compression for images creates ugly artifacts when the original views are SketchUp line drawings with flat colour. JPEG compression is meant to work with photographic content. Turning that off switches the images to PNG which, again, increases output file size but responds well to post production optimisation.
