Is there a way to print multiple scenes without having to go to each tab one at a time?
Use LayOut for that. Set up a viewport for each scene. Then either print directly or export a PDF for printing.
Or you could export images using the native Animation export option and then print the resulting images.
This one will export the scenes to jpgs
Thanks everyone for your input. I did a further search and found something that is useful at
Here are the steps proposed:
- Go to Window → Model Info → Animation → uncheck the Scene Transitions box.
- Go to the File menu → Export → Animation → Image Set
- Use the Options button to adjust the size of the images.
- Export animation.
That’s what I suggested.
Thanks for the clarification. I didn’t understand fully what you meant until I found the step-by-step.
