Printing a template for cutting an oval on a bandsaw
I’m designing a project using Sketchup Studio that involves several oval shapes, all of the same dimension. The oval shape is 15" long by 9.5" wide. I’d like to mosaic print the shape out on paper, glue it to a sheet of plywood, and cut along the paper lines to make a template for the parts to be used in the final project. However, I can’t seem to find any obvious option for printing an actual size rending for this purpose.
Is this possible to do in SketchUp, and if so, can someone point me in a direction to learn how to go about doing it?
SIAP, but I did a quick search and couldn’t find anything on the topic.
Thanks in advance.
Realistically while it can be done with sketchup, it would be far easier with something designed for 2d. Inkscape for example.
I believe opencutlist can export 2d line drawings with smoothing for arcs. Not sure about ellipses. But you could just make a 15" diameter circle and set the segments to somewhere in the 100s, then use the scale tool to squash it to 9.5" tall and print that.
Have you already drawn the ovals, or is that part of the problem? To draw an ellipse in SketchUp you draw a circle and then scale it in one of the axis directions.
To print at real size, you would be better served to send the model to LayOut, where there is better control for printing to scale.
Draw it in SKP
Camera Parallel Projection
Top View
Add Scene
Save File
Send to Layout
Pick paper size large enough to work with your geometry
Set scale 1:1 Full Size
Dimension as needed
Export to PDF
Print - either send to a copy shop with a large format printer or use software that allows you to tile the output into a poster - banner print and print at home.
That worked. Greatly appreciated…thanks.
Click the little ‘solution’ check box on the post that helped, it speeds up people looking for similar answers.
