Precise section view placement
I just discovered that though you can NOT move an existing section view to a precise location, you CAN create a NEW section and snap it to a part of the model (like half way through an arch to show the section at the peak of the arch).
It’s possible if you set up a point to snap to such as with crossing guide lines.
section
[quote=“ron, post:1, topic:88475”]
[/quote] But you can. Add an edge ‘On Section Plane’ and select both, them using the edge’s vertex as handle when moving both
Thanks Dave. I hadn’t thought of sneaking up on it like that. The problem is that the sections have no “handle”. But adding a guide line that gets cut off by the section DOES work as you say.
I was not able to “add an edge ON a section plane” as you described, but Dave’s method of adding a line that gets cut by the section DOES allow snapping to the section (to the end of the line). Maybe that’s what you meant.
Thanks
No. Try the ‘Line’ tool and draw an edge on the section plane, don’t be too hasty and wait for the hint ‘On Section Plane’.
It’s a general solution.
Your RIGHT. I just needed to read what the curser was telling me “on section plane”. I found that your method requires the section to be IN-active (otherwise the line just disappears). Dave’s method allows me to activate the section and still move it. Either way, you really have to set up a target line. I can’t get inferencing to work very well with a bunch of sections in the way. Seems like it would rather snap to the sections.
HEY, I just discovered that you can HIDE sections (Duhh). I had a forest of them. Hiding all but one made it a lot easier to use either method.
Thanks for helping me out with that.
Another Do’h moment. I didn’t ever think to try drawing on the section plane. I didn’t know that was a possible inference.
