Position Camera bug in 2022
Thanks for that, I will point out that web needs the same updating.
I checked on this, and I’m hopeful there will be an update for the web version soon. Don’t know exactly when.
In case anyone missed this, it was fixed in the latest update:
https://forums.sketchup.com/t/about-those-elevations-that-relied-on-the-clipping-bug/190865
FYI @colin, I have just migrated a set of files from SU2021 to SU2022. Within the set of models are numerous Camera>Parallel Projection>Top View Scenes. I did not use the old Bug as part of my workflow (when needed I use Section Planes). Just straight forward Top View selection followed by Zoom Extents. In my case the model Scenes are no longer visible in Top View.
I believe this may be a migration issue (from SU2021 to SU2022) related to the new Position Camera algorithm.
In testing, the same Scenes are visible in Camera>Parallel Projection>Bottom View. I then tried Camera>Perspective and again the same Scenes are visible.
In further testing, I was able to go from Camera>Perspective back to Camera>Parallel Projection>Top View successfully, however the position of the model has, as expected, shifted from my original Scene settings.
I can see for new projects in SU/LO2022 this will not be a problem. For the current project I will continue to use SU/LO2021 (so I have a working solution). Wanted to give the team a heads up.
Best regards.
I made this post at a later date. See if this helps.
Thanks. Seems to be exactly what I am experiencing.
If you need one of my affected SU2021 models, let me know.
This topic was automatically closed after 186 days. New replies are no longer allowed.
