When I used 2021 SketchUp version I was able to install a camera at one point and by clicking on the parallel projection I was able to have a 2D view of the face I wanted without using the section plane function. When I opened the 2022 SketchUp version I realized it was no more possible. I did the same with the Camera but as I click on the Parallel projection it shows me the whole building and not only the room where I put the camera in. Is it normal ? Do I have to always use the plane section now (which would be too bad !).
Make sure that you are using the latest maintenance release of SketchUp 2022.
Thank you. It works !
