Hi All
I have a png logo file that has no background or frame to it. When I import a PNG file it show as square frame like a Jpeg file. So I checked the PNG file and it has no background or frame to it.
In a flat elevation it does not show the frame, then in perspective it shows a frame.
Does anyone know why???
A .png is an image with a transparent background, but it is still a flat rectangle and will caste a shadow as such. If it is showing edges then you need to either remove them or hide them, they may be there because of the way the .png was saved, but however they came about they can be removed.
See here how this logo with no visible edges throws a rectangular shadow, if I explode it the edges appear but I can soften or hide them and they go away again. If you chop away the background you can see the shadow changes shape.
There is a plugin by Tig that will trim .png to correct the shadows.
