Is there an easy way to transfer plugins to SKU Pro 2023 without installing them all separately again?
If you don’t mind chasing loading errors you can copy them from the previous SketchUp version. If you don’t, it’s best to install them fresh so you are sure you’re getting the most current ones. If you are using extensions from Sketchucation like those from Fredo6, install the Sketchucation ExtensionStore tool, sign in and use it to install your bundle of extensions from there.
Thanks DaveR, I feared this would be the outcome.
It shouldn’t take real long if you just get after it.
