Today I got problem I cannot press numpad 7 to input number as usual.
Previously I set up my keyboard short cut Shift + 7 for Fredo Ghost > Create Ghost
Now, even I just press only number 7 on numpad, SketchUp will run Fredo Ghost.
I try to install Fredo Ghost or disable, problem is still there.
(My number is work as normal in other softwares)
Is there anyway I can try to fix this problem ?
I hope I don’t have to uninstall and reinstall SketchUp.
Did you try to change the shortcut already? go to preferences, shortcuts then type Fredo ghost, delete the current shortcut and add a new one if you want.
@francisquitof Thank you very much for your help.
I finally found problem. There is some accident. I assign NumPad 7 to auto reverse face !
I just found it after checking every lines from shortcut list.
Thank you for your suggest. I will not assign shortcut for this kind operation anymore.
I will delete this topic from forum so other users will not waste their time to read.
You dont have the shift key with the numpad 7 as shortcut, its just the numpad 7, you must hold the shift key and press 7, not just hit the shift key and then 7. the shortcut should say Shift+NumPad7
