Hi Dave! Thank you for your help. I have solved my problem, and found a second solution thanks to you, (drawing it).
The other solution I just used is to simply “add more anchor points” while in Illustrator to the Vector and then export it.
It worked pretty well. But drawing it from scratch is the best solution as you did.
