I want to make a round hole making it complicated as you can see. The location of the hole should not change, but flowify is not working even though I’m sure I did it properly. Please can someone take a look it’s urgent
Project.skp (299.3 KB)
Please do not double-post. it is against forum rules. You may edit the original post to add details if you wish.
3D model >
Flowify-02.skp (298.9 KB)
Sorry I dont know rules. What should I do? I didn’t know I was sending 2 posts
Thank you very much. What’s the problem? Could you please tell me why I couldn’t do it?
You’re welcome!
Use this one
Create the right surface for Flowify, taking into account the message it gives.
On the left side (all green), quad surface.
What is the final shape that you actually want to create? Why do you need Flowify?
Did you read that message from Flowify carefully?
Just creating a cylinder and intersecting it with the roof is not enough?
I tried but failed. The surfaces are not separated from each other. I need your help for the last time. I know I took your time, but I would be very grateful. Can you do it for me?
Project Parla.skp (340.8 KB)
Just create the cylinder and intersect it with the roof
I did it! Thak you so much! I can’t thank you enough, I really appreciate it. ![]()
It sounds better that way ![]()
You’re welcome!
