Is there a method to adjust the opacity of an imported PDF site plan to enable easier tracing? I know I can change the line color, to red for example, but wondering if there is another option such as adjusting opacity of PDF?
I’m learning Vectorworks Landmark and this option is available. Makes tracing easier to view over grayed out PDF.
How did you import the PDF as SketchUp doesn’t natively import PDF files? Was it via an extension, or did you convert to a JPEG? Either way, use the sample paint eyedropper under ‘materials’, then you can use the materials edit dialogue to change the opacity.
