Hello All.
Has anyone had this happen, and were you able to correct it?
I’ve exported it a couple of times but got the same results.
Hello All.
Yes, see if the link below is the same as what you’re seeing. I haven’t seen it yet in 2024. I believe the fix was to make the viewport box larger or adjust the clipping mask if you have one.
Thanks for the tip. I’ll check that out and see if I can fix it.
