Pattern on a sphere
I have a sphere an need to place a fishing net pattern on it.
The result should look similar to the one on the picture
ForSUQuestion
I’m ok if the pattern will result being quite even, not like on the original image and more similar to the one on the sketch below
Could you please advise on the best way of achieving this?
I use SU Make17.2.2555
If you want the net to be 3D, you can use Flowify plugin. See below for a quick demo:
sphere_net
Looks perfect, but I’m struggling to create such a surface with such a 3D mesh that is :
  • orientated 45degrees to the rectangle surface edges
  • all the joins at the edges are correctly aligned
Can you please advise how you did it ?
There are probably better ways to do it but here is my way:
1- Draw a square, rotate it 45° and copy
2- Select all lines and use Lines2Tubes plugin.
3- Select all and Right click > Intersect Face > With Selection
4- Use Solid Inspector² plugin to clean mesh and Soften & Smooth edges.
net.skp (643.6 KB)
creating_net
