Goodmorning everyone.
I use the script parametric.rb in some of my scripts and I find it difficult to save the data for the selected face on which I perform the operations provided by my script so that it can be accessed again during edit mode.
I thank the help in advance.
Greetings
Tiziano Traini
# Copyright 2013, Trimble Navigation Limited
# Copyright 2018, By SOFTDEG di Traini Tiziano Certaldo (FI) ITALIA
# se usato in ambito professionale è gradita una donazione
# PayPal : tiziano.traini@tin.it
# This software is provided as an example of using the Ruby interface
# to SketchUp.
# Permission to use, copy, modify, and distribute this software for
# any purpose and without fee is hereby granted, provided that the above
# copyright notice appear in all copies.
# THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
# IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
# Name : SOFTDEG_Vetrate 1.1.0
# Description : Un plugin per creare infissi civili parametrici.
# Menu Item : Tools->SOFTDEG_Vetrate
# Context Menu: Edit SOFTDEG_Vetrate
# Usage : Rileva superficie e immetti le caratteristiche di una vetrata.
# : Per le modifiche successive tasto destro sulla vetrata e
# : selezionare Edita SOFTDEG_Vetrata
# Date : 05/05/2018
# Type : Dialog Box
# Classes per creare ed editare vetrate parametriche
require 'sketchup.rb'
require 'SOFTDEG_vetrate/parametric.rb'
module SOFTDEG_Vetrate
class Vetrate < SOFTDEG_Vetrate::Parametric
#original offset by Rick Wilson
#Smustard
def offset_(face=nil, dist=0)
return nil if not face or not face.valid?
return nil if (not ((dist.class==Fixnum || dist.class==Float || dist.class==Length) && dist!=0))
pi=Math::PI
verts=face.outer_loop.vertices
pts=[]
0.upto(verts.length-1) do |i|
vec1=(verts[i].position-verts[i-(verts.length-1)].position).normalize
vec2=(verts[i].position-verts[i-1].position).normalize
vec3=(vec1+vec2).normalize
if vec3.valid?
ang=vec1.angle_between(vec2)/2
ang=pi/2 if vec1.parallel?(vec2)
vec3.length=dist/Math::sin(ang)
t=Geom::Transformation.new(vec3)
if pts.length > 0
if not (vec2.parallel?(pts.last.vector_to(verts[i].position.transform(t))))
t=Geom::Transformation.new(vec3.reverse)
end#if
end#if
pts.push(verts[i].position.transform(t))
end#if
end#upto
face.parent.entities.add_face(pts) if pts[2]
end#offset_
# Crea vetro doppio, singolo con spessore (thick_v) 0 oppure senza vetro con spessore (thick_v) negativo
def vetro(newFace, width, thick, d_a, thick_v, container)
frame = container.add_group
group_container = frame.entities
if thick_v == 0.mm
thick_v=1.mm
thick_vv=0.mm
end
da=d_a+(thick-thick_v)/2
intFace=offset_(newFace,-width)
telaio_i = intFace.outer_loop.vertices
telaio_i = group_container.add_face(telaio_i)
if not telaio_i.normal.z == 1
telaio_i.reverse!
end
status = telaio_i.material = "vetro_01"
status = telaio_i.back_material = "vetro_01"
vetro1=telaio_i.pushpull((da+thick_v),true)
telaio_i.pushpull(da+(thick_v/2))
@entities.erase_entities(telaio_i.outer_loop.edges,intFace.outer_loop.edges)
intFace = offset_(newFace,-width)
telaio_i.reverse!
end
if not thick_vv == 0.mm
vetro2 = telaio_i.pushpull(da,true)
else
@entities.erase_entities(telaio_i, telaio_i.outer_loop.edges,intFace.outer_loop.edges)
end
newFace.erase!
frame
end #def
# Crea telaio/anta/cornice mediante dimensioni e sfalsamento in asse e offset dalla faccia di partenza (foro muratura)
def anta(newFace1, d_o, d_a, width_a, thick_a, container)
newFacet = newFace1.outer_loop.vertices
newFacet = container.add_face(newFacet)
if d_o == 0.mm
newFace = newFace1
else
newFace = offset_(newFacet,d_o)
newFacet.erase!
end
intFace = offset_(newFace,-width_a)
telaio_e = newFace.outer_loop.vertices
telaio_e = group_container.add_face(telaio_e)
telaio_i.erase!
status = telaio_e.material = "legno_01"
if not telaio_e.normal.z == 1
telaio_e.reverse!
end
anta1=telaio_e.pushpull((d_a+thick_a),true)
telaio_e.reverse!
end
telaio_e.pushpull -d_a
if not d_o == 0
@entities.erase_entities(newFace.outer_loop.edges, intFace.outer_loop.edges)
else
@entities.erase_entities(intFace.outer_loop.edges)
newFacet.erase!
end
frame
end #def
def create_entities(data, container)
# imposta costanti
anta_a=20.mm # Sfalsamento anta dal telaio
thick_c=70.mm # Spessore Cornice
thick_a=70.mm # Spessore Infisso Anta
lista_t=10.mm # Spessore lista interna
lista_d_a=20.mm # Sfalsamento lista dall'anta
# Set values from input data
a99 = data["a99"] # faccia di partenza
a0 = data["a0"].to_l # Cornice esterna Larghezza
a1 = data["a1"].to_l # Telaio infisso Larghezza
a11= data["a11"].to_l # Lista rifinitura interna Larghezza
a2 = data["a2"].to_l # Spessore Vetro
a3 = data["a3"].to_l # Stecche oriz. Larghezza
a4 = data["a4"].to_l # Stecche vert. Larghezza
a5 = data["a5"].to_int # N Stecche orizzontali
a6 = data["a6"].to_int # N Stecche verticali
if a2 > (thick_c-20.mm)
a2=(thick_c-20.mm).to_l
data["a2"]=a2
end
# Remember values for next use
@@face = a99
@@width_c = a0
@@width_a = a1
@@lista_w = a11
@@thik_v = a2
@@width_so = a3
@@width_sv = a4
@@ns_o = a5
@@ns_v = a6
# Inizio creazione vetrata
model = Sketchup.active_model
@entities = model.active_entities
sel = model.selection
# Definisce i due materiali utilizzati
mats=model.materials
if mats["legno_01"]==nil
legno=mats.add("legno_01")
legno.color="Brown"
end#if
if mats["vetro_01"]==nil
vetro=mats.add("vetro_01")
vetro.color="Gray"
vetro.alpha=0.25
end#if
if Sketchup.version_number < 7000000
model.start_operation "Vetrate"
else
model.start_operation "Vetrate", true
end
faces = sel.select{|e| e.typename == 'Face'}
#if not faces.length > 0
#end
model.start_operation("Crea Telaio")
faces.each do |face|
#crea gruppo della faccia originale
tgroup=@entities.add_group
tentities=tgroup.entities
iface=face.outer_loop.vertices
oface=tentities.add_face(iface)
#crea telaio esterno
newFace0=oface
cornice_o=a0
cornice_a=0.mm
cornice=anta(newFace0,cornice_o,cornice_a, 2*a0, thick_c, container)
#crea lista di finitura interna
if a11 > 0
newFace1=oface
# ottimizza sfalsamento cornice finitura interna
if a0 < lista_d_a
lista_d_a=a0/2
end
lista_o=lista_d_a+a11
lista=anta(newFace1, lista_o, thick_c, a11, lista_t, container)
end
#crea anta interna
if a1 > 0
newFace2=oface
anta_o = 0.mm
anta=anta(newFace2,anta_o, anta_a, a1, thick_a, container)
else
a1=a0
anta_a=0
end
#crea vetro
newFace3=oface
if a2 >= 0.mm
vetro=vetro(newFace3, a1, thick_a, anta_a, a2, container)
end
face.erase!
tgroup.erase!
end
model.commit_operation
end #end def
def default_parameters
# Set starting defaults
if !defined? @@width_c # then no previous values input
defaults = {"a0" => 40.mm, "a1" => 80.mm, "a11" => 70.mm, "a2" => 30.mm, "a3" => 40.mm, "a4" => 40.mm, "a5" => 0, "a6" => 0 , "a99" => nil }
else
# Reuse last inputs as defaults
defaults = {"a0" => @@width_c, "a1" => @@width_a, "a11" => @@lista_w, "a2" => @@thik_v, "a3" => @@width_so, "a4" => @@width_sv, "a5" => @@ns_o, "a6" => @@ns_v, "a99" => @@face }
end # if
end # default_parameters
def translate_key(key)
prompt = key
case( key )
when "a0"
prompt = " Cornice esterna Larghezza "
when "a1"
prompt = " Telaio infisso Larghezza "
when "a11"
prompt = " Lista rifinitura interna Larghezza "
when "a2"
prompt = " Spessore Vetro "
when "a3"
prompt = " Stecche oriz. Larghezza "
when "a4"
prompt = " Stecche vert. Larghezza "
when "a5"
prompt = " N Stecche orizzontali "
when "a6"
prompt = " N Stecche verticali "
end
prompt
end
end # Class Vetrate
if (not $Vetrate_menu_loaded)
### commands
cmd1=UI::Command.new("SOFTDEG_Vetrate") { Vetrate.new }
cmd1.tooltip='Vetrate Irregolari Parametriche - donazione PayPal: tiziano.traini@tin.it'
cmd1.status_bar_text='Vetrate Irregolari: Seleziona una faccia ...'
cmd1.small_icon=File.join('SOFTDEG_vetrate', 'SOFTDEG_Vetrate_16x16.png')
cmd1.large_icon=File.join('SOFTDEG_vetrate', 'SOFTDEG_Vetrate_24x24.png')
menu=UI.menu("Tools").add_item(cmd1)
toolbar=UI::Toolbar.new('SOFTDEG_Vetrate')
toolbar.add_item(cmd1)
toolbar.restore if toolbar.get_last_state.abs==1 #TB_VISIBLE/NEVER
$Vetrate_menu_loaded = true
end
end # module SOFTDEG_Vetrate
