I'm new, please help me with this, thanks!
Taken from KScher’s topic I want to get the desired points! I’m a newbie and really need help with the code as well as instructions on how to write this code.
Screenshot_1
class GrooveTool
def initialize
	@selected_face = nil
	@selected_edge = nil
	@transformations = []
	@step = 1
	update_status_text
end
def activate
	reset_tool
end
def deactivate(view)
	view.invalidate
end
def onMouseMove(flags, x, y, view)
	ph = view.pick_helper
	ph.do_pick(x, y)
	path = ph.path_at(0)
	if path
		last_entity = path.last
		if @step == 1 && last_entity.is_a?(Sketchup::Face)
			@selected_face = last_entity
			@transformations = compute_transformation(path)
			view.invalidate
			elsif @step == 2 && last_entity.is_a?(Sketchup::Edge)
			@selected_edge = last_entity
			view.invalidate
		end
	end
end
def onLButtonDown(flags, x, y, view)
	if @step == 1 && @selected_face
		@step = 2
		update_status_text
		elsif @step == 2 && @selected_edge
		prompt_for_groove_parameters
		reset_tool
	end
	view.invalidate
end
def draw(view)
	draw_highlight(view)
end
private
def reset_tool
	@step = 1
	update_status_text
end
def update_status_text
	Sketchup.status_text = case @step
		when 1
		"Оберіть площину"
		when 2
		"Оберіть край на площині"
	end
end
def prompt_for_groove_parameters
	prompts = ["Groove width (mm)", "Groove depth (mm)", "Groove offset (mm)"]
	defaults = ["10", "5", "50"]
	input = UI.inputbox(prompts, defaults, "Setting groove")
	if input
		@groove_width, @groove_depth, @groove_offset = input.map { |value| value.to_f / 25.4 }
		create_groove
	end
end
def create_groove
	return UI.messagebox("Необхідно виділити як площину, так і край!") if @selected_face.nil? || @selected_edge.nil?
	model = Sketchup.active_model
	points = get_groove_points()
	begin
		model.start_operation("Create Groove", true)
		groove_face = @selected_face.parent.entities.add_face(points)
		groove_face.pushpull(-@groove_depth) if groove_face && groove_face.valid?
		rescue => e
		UI.messagebox("Error creating groove: #{e.message}")
		ensure
		model.commit_operation
	end
end
def get_groove_points
	edge_vector = @selected_edge.line[1].normalize
	offset_vector = @selected_face.normal * edge_vector
	if @groove_offset > 0
		offset_vector.length = @groove_offset
		test_point = @selected_edge.start.position.offset(offset_vector)
		if @selected_face.classify_point(test_point) == Sketchup::Face::PointOutside
			offset_vector.reverse!
		end
		offset_start_point = @selected_edge.start.position.offset(offset_vector)
		offset_end_point = @selected_edge.end.position.offset(offset_vector)
		offset_vector.length = @groove_width
		width_start_point = offset_start_point.offset(offset_vector)
		width_end_point = offset_end_point.offset(offset_vector)
		else
		width_vector = @selected_face.normal * edge_vector
		width_vector.length = @groove_width
		test_width_point = offset_start_point.offset(width_vector)
		if @selected_face.classify_point(test_width_point) == Sketchup::Face::PointOutside
			width_vector.reverse!
		end
		width_start_point = offset_start_point.offset(width_vector)
		width_end_point = offset_end_point.offset(width_vector)
	end
	points = [
		offset_start_point, offset_end_point, width_end_point, width_start_point
	return points
end
def compute_transformation(path)
	transformation = Geom::Transformation.new
	path.each do |entity|
		if entity.respond_to?(:transformation)
			transformation *= entity.transformation
		end
	end
	transformation
end
def draw_highlight(view)
	if @selected_face
		points = @selected_face.outer_loop.vertices.map(&:position)
		transformed_points = points.map { |point| point.transform(@transformations) } if @transformations.is_a?(Geom::Transformation)
		view.drawing_color = 'yellow'
		view.draw(GL_POLYGON, transformed_points)
	end
	if @selected_edge
		points = @selected_edge.vertices.map(&:position)
		view.line_width = 5
		view.drawing_color = 'blue'
		view.draw(GL_LINES, transformed_points)
	end
end
end
Sketchup.active_model.select_tool(GrooveTool.new)
The first thing to learn is how to properly quote code on the forum:
The second thing to learn is that you need a good code editor. Here are 2 free code editors:
The third thing is to learn the basics of Ruby:
Fourth would be to study the SketchUp Ruby documentation:
Finally, learn how to ask precise well written questions …
  • We do not know what points you wish “to get”, or what “to get” means …
    • What do you want to do with some “points” (assuming you tell us what points you want.)
  • We have no idea why you reposted KScher’s GrooveTool code …
    • or which version of it, ie, what topic and post it came from …
    • nor how it relates to “getting points”
:question:
Thank you for your response, I will follow the steps you stated above.
Explain to us what you are trying to build. You can just use pictures.
  • I’m sorry, I’m not yet proficient in how to post and reply even though I’ve consulted the guidelines.
  • I repeated DanRathbun’s method and created 2 D35 margin hole drilling vectors, but the problem happened again: the coordinate axis was not as expected.
class GrooveToolA
  def initialize
    @transformations = IDENTITY
    @step = 1
    update_status_text
  end
  def activate
    reset_tool
  end
    view.invalidate
  end
		ph.do_pick(x, y)
		path = ph.path_at(0) # get the path to the selected element
		if path
				@selected_path = path # keep the path to the face
				@transformations = ph.transformation_at(0)
				elsif @step == 2 && last_entity.is_a?(Sketchup::Edge) && @selected_face.edges.include?(last_entity)
				# There is no need to store the path to the edge, as it must be in the same context as the face
			end
		end
		view.invalidate
	end
      @step = 2
      update_status_text
      reset_tool
    end
    view.invalidate
  end
  def draw(view)
  end
  private
  def reset_tool
    @step = 1
    update_status_text
  end
      when 1
      "Оберіть площину"
      when 2
    end
  end
		defaults = ["10", "5", "21.5"]
		if input
			create_groove
		end
	end
  def create_groove
		get_groove_points
        #points = get_groove_points()
		# We define the context based on the stored path
		container = @selected_path[-2] # The penultimate element in the path is the parent container
		entities = nil
		if container.is_a?(Sketchup::ComponentInstance) || container.is_a?(Sketchup::Group)
			# We make the container unique if it is not the root context of the model
			unique_container = container.make_unique
			entities = unique_container.definition.entities
			else
			entities = model.active_entities # If not in a group or component, we use the model context
		end
		if entities
              a_layer = model.layers.add("ABF-D35")
              model.active_layer = a_layer
              @cachmep = 100.mm
              group_line_1 = entities.add_group
              group_face_1 = entities.add_group
              @line_1 = group_line_1.entities.add_line(@pt1, @pt4)
              @face_1 = group_face_1.entities.add_face(@pt1, @pt2, @pt3, @pt4)
              group_line_1.erase!
              group_face_1.erase!
              line_vector_1 = @line_1.line[1].normalize
              offset_vector_1 = @face_1.normal * line_vector_1
              offset_vector_1.length = @cachmep / scale_factor(offset_vector_1)
               test_point_1 = @pt1.offset(offset_vector_1)
            if @face_1.classify_point(test_point_1) == Sketchup::Face::PointOutside
              offset_vector_1.reverse!
            end
              start_point_1 = @pt1.offset(offset_vector_1)
              end_point_1 = @pt4.offset(offset_vector_1)
              radius_1 = 17.5.mm / scale_factor(offset_vector_1)
              group1 = entities.add_group
              group1.name = "ABF_D35"
              group1.material = "orange"
              circle1 = group1.entities.add_circle(start_point_1, @face_1.normal, radius_1)
              group_line_2 = entities.add_group
              group_face_2 = entities.add_group
              @line_2 = group_line_2.entities.add_line(@pt2, @pt3)
              @face_2 = group_face_2.entities.add_face(@pt1, @pt2, @pt3, @pt4)
              group_line_2.erase!
              group_face_2.erase!
              line_vector_2 = @line_2.line[1].normalize
              offset_vector_2 = @face_2.normal * line_vector_2
              offset_vector_2.length = @cachmep / scale_factor(offset_vector_2)
               test_point_2 = @pt2.offset(offset_vector_2)
            if @face_2.classify_point(test_point_2) == Sketchup::Face::PointOutside
              offset_vector_2.reverse!
            end
              start_point_2 = @pt2.offset(offset_vector_2)
              end_point_2 = @pt3.offset(offset_vector_2)
              radius_2 = 17.5.mm / scale_factor(offset_vector_2)
              group2 = entities.add_group
              group2.name = "ABF_D35"
              group2.material = "orange"
              circle2 = group2.entities.add_circle(start_point_2, @face_2.normal, radius_2)
              layer0 = model.layers.add("Layer0")
              model.active_layer = layer0
			else
			UI.messagebox("Не вдалося ідентифікувати контекст для створення пазу.")
		end
	end
  # This method will calculate a scale factor at the direction of
  #  given vector
  def scale_factor(vector)
    vector.normalize.transform(@transformations).length.to_f
  end
    offset_vector.length = @groove_offset / scale_factor(offset_vector)
    # Checking if an offset point lies on a face
    end
    # Apply offset to create groove start points
    # Determination of additional points for forming the width of the groove
    offset_vector.length = @groove_width / scale_factor(offset_vector)
    @pt1 = offset_start_point
    @pt2 = offset_end_point
    @pt3 = width_end_point
    @pt4 = width_start_point
    #puts points.inspect
    #return points
  end
  # This method wont be used...
      end
    end
    transformation
    # ... however an alternative one-liner method:
    # transformation = path[0..-2].map(&:transformation).inject(IDENTITY, :*)
  end
    if @selected_face
    end
    if @selected_edge
      view.line_width = 5
    end
  end
end
Sketchup.active_model.select_tool(GrooveToolA.new)
I have no idea what this means.
