I have try to study the official example code and put “n” points into a array.
unfortunately,it can’t work.this is the code
def activate
@mouse_ip = Sketchup::InputPoint.new
@picked_first_ip = Sketchup::InputPoint.new
update_ui
end
def draw(view)
@mouse_ip.draw(view) if @mouse_ip.display?
update_ui
end
def onMouseMove(flags, x, y, view)
@mouse_ip.pick(view, x, y)
view.tooltip = @mouse_ip.tooltip if @mouse_ip.valid?
view.invalidate
update_ui
if picked_first_point?
@mouse_ip.pick(view, x, y, @picked_first_ip)
else
end
view.invalidate
end
def onLButtonDown(flags, x, y, view)
@mouse_down = Geom::Point3d.new(x, y)
@pick_first_ip = mouse_down
reset_tool
else
@picked_first_ip.copy!(@mouse_ip)
end
end
def reset_tool
@picked_first_ip.clear
update_ui
end
def update_ui
Sketchup.status_text = 'select the first point'
else
Sketchup.status_text = 'select the second point'
end
end
def picked_points
points = []
points << @picked_first_ip.position if picked_first_point?
points << @mouse_ip.position if @mouse_ip.valid?
ip1 = points[0]
ip2 = points[1]
if points.size == 2 #there “2” maybe 3 or 7……N
UI.messagebox(ip1)
UI.messagebox(ip2)
else
end
end
Maybe I have got wrong understand the method of pick.
someone can help me thanks!
You code has several errors…
Firstly it should be inside a class so a Tool gets made…
Next you have a mix of @xxx and xxx variables - these are not the same…
So when you
picked_first_ip = ...
Is not the same reference as
@picked_first_ip
or
picked_first_point?
You are making your code more convoluted and hard to debug…
Later
is used but mouse_down is undefined ? BUT @mouse_down is set up !
A @xxx variable is shared across methods but your
is limited to its own method so is always nil !
Try using @picked_first_point
There is not final ? in the variable’s name…
The method picked_points() is never called in your code.
I’m afraid you code is perhaps beyond redemption, without a major rewrite…
This is NOT a major audit - just some issues that jumped out…
It’s a hobbyhorse of mine, but I don’t think the difference between local variables, global variables, method arguments, and @ variables is properly taught most places.
Globals should be the exclusive province of the language and core functions, never created by any user script. There is no way to protect against collisions between use of the same named global across unrelated contexts. Such clashes cause errors that are extremely hard to debug.
@variables are widely misused, IMO. They are meant to preserve an object’s memory of its “state”. That is, what it needs to remember so as to respond correctly to subsequent function calls. They are essential to handle callbacks from the GUI, since Ruby gives up control between such calls; other sorts of memory of what callbacks came before is lost unless retained in @ variables. They aren’t meant as a way to pass data “around the side” when one function calls another on the same object! When code is written so that values are passed via @ instead of explicit parameters it becomes impossible for any other object to safely call that function. Said another way, the object has a contract with itself (that required data is in an @) but gives no such promise to anything else. But even in a single object, the practice makes it hard to be sure what the function relies on without studying the entire code body. Oh, this function uses @foo I wonder when and why it was last assigned?
Misuse of @ is especially common in code that is actually function-oriented not object-oriented. Code snippets posted here on the forum often use @ variables for everything, even going so far as to pass them as parameters to a function on the same object or to use them as temporaries not needed outside or after the current function (for which local, non-@ is the right kind).
