Incorrect calculation of point distance after scaling
This is a continuation of my grooving tool coding attempts posted here: "Points are no planar" error message when creating a face - #8 by KScher
I would like to ask you to solve another problem that I am facing and I don’t know how to solve it. The tool code works well on unscaled objects. But if I scale the group, the face creation points are calculated incorrectly. How can this be solved for scalable objects?
class GrooveTool
	def initialize
		@selected_face = nil
		@selected_edge = nil
		@transformations = []
		@step = 1
		update_status_text
	end
	def activate
		reset_tool
	end
	def deactivate(view)
		view.invalidate
	end
	def onMouseMove(flags, x, y, view)
		ph = view.pick_helper
		ph.do_pick(x, y)
		path = ph.path_at(0)
		if path
			last_entity = path.last
			if @step == 1 && last_entity.is_a?(Sketchup::Face)
				@selected_face = last_entity
				@transformations = compute_transformation(path)
				view.invalidate
				elsif @step == 2 && last_entity.is_a?(Sketchup::Edge)
				@selected_edge = last_entity
				view.invalidate
			end
		end
	end
	def onLButtonDown(flags, x, y, view)
		if @step == 1 && @selected_face
			@step = 2
			update_status_text
			elsif @step == 2 && @selected_edge
			prompt_for_groove_parameters
			reset_tool
		end
		view.invalidate
	end
	def draw(view)
		draw_highlight(view)
	end
	private
	def reset_tool
		@step = 1
		update_status_text
	end
	def update_status_text
		Sketchup.status_text = case @step
			when 1
			"Оберіть площину"
			when 2
			"Оберіть край на площині"
		end
	end
	def prompt_for_groove_parameters
		prompts = ["Groove width (mm)", "Groove depth (mm)", "Groove offset (mm)"]
		defaults = ["10", "5", "50"]
		input = UI.inputbox(prompts, defaults, "Setting groove")
		if input
			@groove_width, @groove_depth, @groove_offset = input.map { |value| value.to_f / 25.4 }
			create_groove
		end
	end
	def create_groove
		return UI.messagebox("Необхідно виділити як площину, так і край!") if @selected_face.nil? || @selected_edge.nil?
		model = Sketchup.active_model
		points = get_groove_points()
		begin
			model.start_operation("Create Groove", true)
			groove_face = @selected_face.parent.entities.add_face(points)
			groove_face.pushpull(-@groove_depth) if groove_face && groove_face.valid?
			rescue => e
			UI.messagebox("Error creating groove: #{e.message}")
			ensure
			model.commit_operation
		end
	end
	def get_groove_points
		edge_vector = @selected_edge.line[1].normalize
		offset_vector = @selected_face.normal * edge_vector
		if @groove_offset > 0
			offset_vector.length = @groove_offset
			test_point = @selected_edge.start.position.offset(offset_vector)
			if @selected_face.classify_point(test_point) == Sketchup::Face::PointOutside
				offset_vector.reverse!
			end
			offset_start_point = @selected_edge.start.position.offset(offset_vector)
			offset_end_point = @selected_edge.end.position.offset(offset_vector)
			offset_vector.length = @groove_width
			width_start_point = offset_start_point.offset(offset_vector)
			width_end_point = offset_end_point.offset(offset_vector)
			else
			width_vector = @selected_face.normal * edge_vector
			width_vector.length = @groove_width
			test_width_point = offset_start_point.offset(width_vector)
			if @selected_face.classify_point(test_width_point) == Sketchup::Face::PointOutside
				width_vector.reverse!
			end
			width_start_point = offset_start_point.offset(width_vector)
			width_end_point = offset_end_point.offset(width_vector)
		end
		points = [
			offset_start_point, offset_end_point, width_end_point, width_start_point
		return points
	end
	def compute_transformation(path)
		transformation = Geom::Transformation.new
		path.each do |entity|
			if entity.respond_to?(:transformation)
				transformation *= entity.transformation
			end
		end
		transformation
	end
	def draw_highlight(view)
		if @selected_face
			points = @selected_face.outer_loop.vertices.map(&:position)
			transformed_points = points.map { |point| point.transform(@transformations) } if @transformations.is_a?(Geom::Transformation)
			view.drawing_color = 'yellow'
			view.draw(GL_POLYGON, transformed_points)
		end
		if @selected_edge
			points = @selected_edge.vertices.map(&:position)
			view.line_width = 5
			view.drawing_color = 'blue'
			view.draw(GL_LINES, transformed_points)
		end
	end
end
Sketchup.active_model.select_tool(GrooveTool.new)
Actually, thinking about it, … it is acting as intended. What you are doing is drawing the groove in the definition’s unscaled entities collection. (I.e., instances do not have an entities collection.)
So, the groove is really drawn 50mm from the second selected edge. But then that instance is scaled such that everything in it’s red axis is stretched by 1/5. So, in the instance the offset is 60mm and the groove width will be 12mm.
Yes, I understand that. But I’m looking for a way to update the scaling data. The groove should always be built according to the parameters entered, regardless of the scaling of the parent object.
Then would you make the parent unique and scale its definition as per normal as per materials?
Thanks for the reply, but it won’t fix it. I often use groups that are already unique.
Silly question have you tried using components instead of groups? I have found group scaling to be problematic where a component works fine…
You need to consider scale factor at the direction of offset vector. (More in a code)
The PickHelper #transformation_at method already give combined transformation of all groups, components and images in the pick path. You can use that instead.
Also need to check if the edge is part of the selected face boundaries, to ensure the same context. You already have a @transformations calculated, do not need to compute again. The view.invalidate can be moved out of condition since it is used in both cases.
“We” do not like that!
Use String #to_l method. See more notes in code.
__
The modified, commented code:
class GrooveToolA
  def initialize
    @transformations = IDENTITY
    @step = 1
    update_status_text
  end
  def activate
    reset_tool
  end
    view.invalidate
  end
    ph.do_pick(x, y)
    if path
        # You can retrieve the combined transformations by this method:
        @transformations = ph.transformation_at(0)
      #Also need to check if the edge is part of the selected face
      # boundaries, to ensure the same context
      elsif @step == 2 && last_entity.is_a?(Sketchup::Edge) &&
            @selected_face.edges.include?(last_entity)
        # You have already a transformation, no need to calculate again
      end
    end
    # Lets put out of the contrition's
    view.invalidate
  end
      @step = 2
      update_status_text
      reset_tool
    end
    view.invalidate
  end
  def draw(view)
  end
  private
  def reset_tool
    @step = 1
    update_status_text
  end
      when 1
      "Оберіть площину"
      when 2
    end
  end
    prompts = ["Groove width", "Groove depth", "Groove offset"]
    # Store defaults in instance variable, if not entered yet
    #  the predefined mm values will be taken
    # the UI.inputbox will display and format the values according to
    # unit settings in Model Info
    @defaults ||= [ 10, 5, 50 ].map{|s| s.mm}
    begin
      input = UI.inputbox(prompts, @defaults, "Setting groove")
      if input
        # lets use the powerful to_l to convert string to internal unit
        # this will allow users their Unit settings
        # "manual" calculation is not preferred
        @groove_width, @groove_depth, @groove_offset = input.map { |v| v.to_l }
        # Reassign defaults
        # so last entered value can be used next time
        @defaults = [ @groove_width, @groove_depth, @groove_offset ]
        create_groove
      end
    rescue
      UI.messagebox( "Invalid length!\nType integer as a current unit or 50mm or 1.9\" for example" )
    end
  end
  def create_groove
    begin
    rescue => e
    ensure
    end
  end
  # This method will calculate a scale factor at the direction of
  #  given vector
  def scale_factor(vector)
    vector.normalize.transform(@transformations).length.to_f
  end
      # You need to correct the length of vector by factor
      # determined the context transformation and direction
      offset_vector.length = @groove_offset / scale_factor(offset_vector)
      end
        # consider scale factor here too
        offset_vector.length = @groove_width / scale_factor(offset_vector)
      else
        width_vector.length = @groove_width / scale_factor(width_vector)
      end
    end
    # You do not need to use return keyword at the end
    # the  last "line" is returned. (Even you can omit to assign variable)
    [ offset_start_point, offset_end_point, width_end_point, width_start_point ]
  end
  # This method wont be used...
      end
    end
    transformation
    # ... however an alternative one-liner method:
    # transformation = path[0..-2].map(&:transformation).inject(IDENTITY, :*)
  end
    if @selected_face
    end
    if @selected_edge
      view.line_width = 5
    end
  end
end
Sketchup.active_model.select_tool(GrooveToolA.new)
_
_
Other notes:
  • Your code above contains tabs characters, this is why the forum engine can not properly show the indentation level. Use only spaces for indentation. No hard tabs. (<< in this link you can find other useful rules, advises)
  • The PickHelper class is very powerful.
    There is a #picked_edge method , #picked_face method and these can be retrieved at once (in one pick). The pick can return multiple pick records (pick path). For example, if the pick hits at the border of an edge and face inside a group there will be two pick paths - one for the face and one for the edge. Actually if you exchange the methods below you can get the face and edge in one step and get the transformation from one of the pick path:
    ph.do_pick(x, y)
    face = ph.picked_face
    edge = ph.picked_edge
    if edge && face && face.edges.include?(edge)
      index = ph.count.times.find { |i| ph.leaf_at(i) == face }
      @transformations = index ? ph.transformation_at(index) : IDENTITY
      @selected_face = face
      @selected_edge = edge
    else
    end
    view.invalidate
  end
    if @selected_face && @selected_edge
      reset_tool
    end
    view.invalidate
  end
See also: PickHelper — A Visual Guide – Procrastinators Revolt!
Köszönöm, @desmo. It works great. And your comments on the code and here on the forum have clarified many important coding questions for me. Thank you.
Be careful with it :wink::
Groups in SketchUp are very similar to components, but can from a user point of view be thought of as unique objects. Groups can be instanced when copied but are silently made unique when edited through the GUI. To honor this behavior, make sure to call #make_unique before modifying a group through the API.
group_uniq
Sorry, I would like to ask again for help in fixing the code. I just try to make each band unique before I add a groove. It seems like it should be simple, but I can’t do it. What am I missing?
First I did this:
def create_groove
  begin
    # make the parent group of the selected face unique
    @selected_face.parent.make_unique if @selected_face.parent.is_a?(Sketchup::Group)
  rescue => e
  ensure
  end
end
Then I came to this:
def create_groove
  begin
    # keep the link to the original group
    original_group = @selected_face.parent
    if original_group.is_a?(Sketchup::Group)
      original_group.make_unique
      # get a new copy of the face and edge in the original group
      @selected_face = original_group.entities[@selected_face.entityID]
      @selected_edge = @selected_face.edges.find { |e| e.entityID == @selected_edge.entityID }
    end
    groove_face = original_group.entities.add_face(points)
  rescue => e
  ensure
  end
end
But none of this works. What am I missing?
I think I managed to fix it. I did not consider the correct context (path).
		ph.do_pick(x, y)
		path = ph.path_at(0) # get the path to the selected element
		if path
				@selected_path = path # keep the path to the face
				elsif @step == 2 && last_entity.is_a?(Sketchup::Edge) && @selected_face.edges.include?(last_entity)
				# There is no need to store the path to the edge, as it must be in the same context as the face
			end
		end
		view.invalidate
	end
	def create_groove
		# We define the context based on the stored path
		container = @selected_path[-2] # The penultimate element in the path is the parent container
		entities = nil
		if container.is_a?(Sketchup::ComponentInstance) || container.is_a?(Sketchup::Group)
			# We make the container unique if it is not the root context of the model
			unique_container = container.make_unique
			entities = unique_container.definition.entities
			else
			entities = model.active_entities # If not in a group or component, we use the model context
		end
		if entities
			groove_face = entities.add_face(points)
			groove_face.pushpull(-@groove_depth) if groove_face.valid?
			else
			UI.messagebox("Не вдалося ідентифікувати контекст для створення пазу.")
		end
	end
You figured it out.:+1:
The trick is that the Entity #parent method returns (Sketchup::ComponentDefinition, or Sketchup::Model), and these don’t have make_unique mehtod. Therefore - as you did - you need to use the last but one element of path to get the instance.
