[PAID JOB] Seeking Structural VDC Modeler for High-End Residence (Framing & Steel Focus)
Hi everyone,
I am looking to hire a SketchUp expert with a strong background in VDC (Virtual Design and Construction) or structural drafting. We are in the pre-construction phase of a high-end custom home and require a highly accurate “digital twin” of the structure based on our engineer’s drawings.
This is NOT a visualization/rendering job. I do not need textures, lighting, or furniture. I need a virtual build of the structural bones of the house.
The Project:
Type: High-end custom residential.
Inputs Provided: Full set of Structural Engineering drawings (PDF/DWG) and Architectural plans.
Goal: To verify constructability, catch clashes between steel/framing and architectural intent, and visualize complex connections.
The Scope:
Foundation: Accurate modeling of footings, stem walls, piers, and slab steps.
Steel: Modeling of all structural steel (beams, columns, posts) per the schedule.
Framing: Modeling of floor systems (joists/trusses), wall framing (studs, headers, rough openings), and roof framing (rafters/trusses) accurately representing the load path.
Technical Requirements:
Solid Modeling: All geometry must be “watertight” solids.
Strict Organization: Mastery of the Outliner and Tags is non-negotiable. I expect a clean hierarchy (e.g., Level 1 > Steel > Beams).
Components vs Groups: Must utilize Components for all repetitive elements (joists, studs) to allow for easy updating.
Plugin Proficiency: Experience with Profile Builder 3 or Quantifier Pro is highly preferred.
Deliverables:
• A clean, optimized .skp file organized by structural material and building level.
To Apply:
Please DM me or reply here. When you apply, please include:
1. A brief mention of your experience with structural modeling.
2. A screenshot of the Outliner/Layer setup from a previous project (to demonstrate organization).
3. An example image showing a model in X-Ray or Wireframe mode.
Thank you.
you need to look for Bob McCarter at Clear Plan Modeling: https://clearplanconsulting.biz
I’m capable (see this post), but not sure of the schedule commitment at this time. I would suggest Bob McCarter as well.
I would also highly recommend Bob McCarter or Robert Coolidge (@RTCool) or any of the designers who have been contributing to this thread:
All of their work is insanely detailed and equally impressive.
Thank you
I will reach out to you to discuss.
