Hi, can somebody tell me what the output resolution is, and whether (or not) this affects line weight (does 1.0x line weight = 1 pixel)?
It seems like the resolution is around 300dpi but some areas are a bit more grainy than others.
Is it technically possible to output at a higher DPI (eg 600, which most laser printers now produce?)
It does…kind of… But only for edges. Hybrid renders edges (lines) as vector graphics so DPI is not relevant at all for edges since vector can be scaled to any resolution with no pixelation. The materials in the SU model however are rasterized so those may still pixelate.
If you want to share your LO file I can take a closer look for you. PM it you don’t want to or can’t share here.
LayOut raster output resolution is controlled by the Output Quality setting in the Document setup >Paper dialog. Low=96 DPI (72 on MAC), Medium = 150 DPI, High = 300 DPI.
The pixelation you see is possibly caused by keeping on the “Use JPG compression” setting in the PDF export options. JPG compression looks terrible in images with areas of uniform colour. You get better results by exporting without compression, and, if necessary using the optimization option in a PDF editor like Acrobat or PDF Exchange editor afterward if the file size needs to be made smaller.
As to the necessity of higher than 300 DPI resolution, that is in practice the highest that any colour printer can reproduce. They use dithering to create colours, so to reproduce to 300 PPI you need a printer with at least 1200 DPI resolution. The only printer type that can create continuous colour is a dye sublimation printer, and they, too, max at 300 PPI.
I’ve attached a little snippet zoomed in and one at 100%) showing the resolution issue;in this case the example shows an area becoming grainy for text (which was generated in SU, not LO).
This is printed in Raster (HQ and no JPG compression). I accept that it would look crisp in vector or hybrid, but vector will loose detail in other parts of these plans, and hybrid just takes too long & freezes LayOut, plus (when it does work) it often has grainy/block areas around critical details.
I can workaround the issue by creating a custom template at A1 size (instead of A3) which should give me a boost in resolution - haven’t actually compared the results of each carefully yet, but that’s my next step. I will be printing these at A1 or A0 size for this project.
I used to do a lot of Site plans/renderings in Photoshop and we always used 600dpi as a minimum for technical drawings; the results were very noticeable for linework and fine textured details.
I’m happy to upload some of my output files as a message but dont want to post them in a public forum for confidentiality reasons.
If you’re curious, the specs on my A1 printer are as follows:
Print resolution Up to 2400 x 1200 optimized dpi
Ink types Dye-based (C, G, M, pK, Y); pigment-based (mK)
Ink cartridges 6 (cyan, gray, magenta, matte black, photo black, yellow)
Line accuracy +/- 0.1%
Minimum line width 0.02 mm (0.0008 in) (HP-GL/2 addressable)
Guaranteed minimum line width 0.07 mm (0.0028 in) (ISO/IEC 13660:2001(E))
Is this still true in SU2024? I output a set of drawings last night to PDF & the saved file size was much bigger than expected. To test things I saved just one A3 size page with a raster perspective image of my building on the High setting and it came in at 9.9Mb. I then saved again at Medium and the file size dropped to 1.1Mb.! Obviously the bigger file looks great on my Retina screen, but the medium image looks fuzzy. My problem is keeping the file sizes down for distribution without resorting to a file download service. Any suggestions why the file size might be jumping so much between resolution settings?
Perhaps as has been suggested elsewhere on this forum it’s time we were given control over the raster resolution DPI setting for output.
sounds like medium is 100dpi and high is 300dpi then.
in 22 or 23, they lowered the low and medium display resolutions, maybe they adjusted the export ones as well.
FYI, an A3 at 300dpi is roughly 3500 x 5000px, that’s 17,5M pixels.
SU exports RGB images where each colour uses a byte, so an uncompressed pixel weight 3b.
a truly uncompressed format (say TIFF) could weight up to 50+ mb
When exporting to PDF, you also have the option of using JPEG compression on images. That would perhaps reduce the file size further, but I don’t use it as IMO it creates ugly compression artifacts with flat colours and dark lines as SketchUp output tends to look like. I understand that when JPEG compression is turned off, the export uses lossless PNG instead. JPEG is good for photographic-type output.
I have done a bit more testing and would concur the High looks like 300 DPI output.
So at 300DPI my page size is 9.9MB
However, if I output my view direct from SU to .PNG at 144 DPI the PNG is only 1.8Mb. Importing it to replace the SU view gives me a page file size of 2.5Mb when output on high setting. Obviously the output isn’t as crisp as using a SU View with 300 DPI but the image quality vs File size is a much better trade off. It’s just a potentially unnecessary work around.
From the image quality of the medium I can only agree with @ateliernab that the export appears to have been set to 96 / 100 DPI, which to me doesn’t look great particularly with AO.
So is there any chance we can be trusted with the DPI output setting?
If not please can we get the medium output to 144/150 DPI and the low at 100/96/72 DPI?
