This one’s a bit odd and I don’t know if it’s a bug, a setting or my old brain. I’m running SketchUp 2022 on OSX Monterey. I’m using a Microsoft Bluetooth 3600 mouse along with a 3DConnexion SpaceMouse Compact. As far as I know all drivers are up to date.
My problem is that when I am trying to orbit with the regular mouse it tends to use whatever object the pointer is over when I start orbiting as the center of the orbit. If the pointer is over a wall it orbits around the wall, whether it’s selected or not. If the mouse happens to be over the sky then the entire model spins off into a Kansas tornado. Even if I have an object selected, but the mouse cursor is not on top of it it will still orbit around whatever the pointer is over.
This gets very frustrating if you have a very simple model where most of the screen space is empty. unless you make sure the cursor is over something it all flies away.
It does the same with the 3D mouse. The pivot point changes to whatever the cursor is over.
When I spend the extra time making sure the cursor is over what I want to orbit and then zoom in or out with the wheel, if the cursor ends up over anything else during that time it will orbit using the other object. This is very frustrating when zoomed into something close and the cursor just happens to be over an open space and the model suddenly zooms way out.
When I’ve watched Aaron’s live streams it doesn’t appear that he has the same issues.
Am I just an old guy yelling at the sky, or is there some setting I can change?
Thanks
Randy
