Orbit with Fredo Corner
Hello everyone,
I don’t know if this problem has a solution or not, but when I use the Fredo Corner plugin, the orbital movement is not normal, it does not rotate in the same way when I do not use this plugin
I don’t know if it’s clear to you but I would like to find a solution to change this mode of movement
Thanks for your answer
You need to give us more than “not normal”. Show a screen capture video or something. I just checked and it looks fine to me. The colored lines disappear while orbiting but that is normal. They come back when orbiting stops.
orbit
This is what it looks like :
I don’t seem to be able to duplicate it. Maybe you could share the model and @Fredo6 might be able to see something.
I can’t…
It does that with every model but only with my sketchup licence
FredoCorner has its own Orbit implementation in order to keep showing the red / green lines and other decoration. I would probably use Overlay now, but it’s available in SU2023 and above.
Can you make sure you run the latest version of LibFredo6 (v15.1). I remember I made a fix on this Orbit in one of the latest version.
I uninstalled and reinstalled libfredo in version 15.1, I still have the same problem…
