If I reinstall I just need to copy my Key?
Reinstalling should fix it at least temporarily. Yes, you should just need your Serial Number.
ok thanks⌠my boss is freaking out
thinks Iâm a tard, iâve been doing this for 9 yearsâŚ
I was almost certain I forgot how to do it⌠;0
I can only seem to find 2018 sketchup download⌠and it will cost me another $240
any idea where to find the 2017 download?
You donât have to re-install. Click in the red circle, and close the file path view option, and select:
wow I guess I am dumb⌠that worked⌠thanks everyone
That doesnât reset the buttons for me. Iâd already tried that. When the files are hidden you canât resize the sheet and it stays in the state it was in (good or bad).
OK, well, that pulldown, which is too long to fit in the space, below the Templates folder, is the Format pulldown. DWG/DXF is the last of 4 selections on that pulldown. Hit tab 4 times, then hit space bar (to select that pulldown), then type the number 4, and type Enter. Youâve now selected DWG/DXF. Hit tab, then space bar, to select the option menu. DWG/DXF options should appear. Make your selections, hit enter. Now you can click on Save and it should save.
I donât know how you got into this mess, but export first and weâll get those values cleared after that.
One thing this presumes: that youâve got âAll Controlsâ set in System Prefs ->Keyboard->Shortcuts (at the bottom of that panel). You can toggle it on or off anytime using Crtl-F7. If you donât do that, you wont be able to get to the Option button.
The underlying issue here is a bug in this DWG dialog in certain versions of OS X - the layout constraints arenât set properly for the buttons that allow you to choose the type of export. Weâve got a fix in progress for this. Until then, youâll have to follow Barryâs instructions to access those options.
Thanks,
Marc
So i have 2018 Pro with the same problem. Still waiting for the bug fix please!!!
martin
Have you had any success with the workarounds mentioned above? In particular, if you make that dialog small by clicking on the drop arrow next to the âSave Asâ field, you should be able to access the âOptionsâ button again.
Hi Marc,
I have now clicked on the drop down arrow and can now find the format
options.
I must say that this is rather bizzare and not intuitive at all.
But thanks
Martin.
Yeah, itâs definitely a bug and weâll get a fix out, but in the meantime this will keep you working. Thanks for your patience.
-m
