Option copy move not working 2015
I can’t get option/copy to work. Help!
What’s your problem exactly?
When I hold the option key and use the move tool i don’t get a copy. Just moves the original
Sent from mobile device
You don’t hold it down, you just click it once to turn copying on or off. There is a plus icon visible in the Move tool icon when copying is active.
On the PC you use the Ctrl key
Anssi.
Thanks, but I tried that too - no plus sign shows up.
Hello, I have the exact same issue on an Macbook Air running 10.9.2
I’ve tried everything I can think of. Rather than seeing a plus symbol I see what looks like two vertical lines side by side when I use the Option key.
This has me stumped … any help gratefully received.
cheers
ben
Ben,
The two vertical lines symbol is default for the Command Key.
My guess is to check your hotkey preferences, maybe they got switched.
