How can I do?
I can’t use Ctrl to copy things when I use “MOVE” this instruction.
When you tap the CTRL key you should see the cursor change to have a + sign. While it has the + showing it will make a copy when you do the move.
Why I tap the CTRL key but can’t see the + sign?
This problem has bother me for a while.
Perhaps you’re using a Mac. If you are, it would be the Option key that you tap.
I use Windows,and I can use this function before still one day open the SketchUp.
But if it didn’t work what setting should I check
I even download again the Sketchup
I have same problem.
‘Ctrl’ key does not work for copying while using MOVE.
If you have your one fixed please tell me how you fixed it.
I use windows10 and SU2021pro.
I also have SU2020pro but this one works without any problem…
