Ever since I’ve updates Sketchup 2021 to the newest version my Ctrl-key is set up differently.
Before, when I would press CTRL-key whilst in the ‘move’-modus it would immediately add a little ‘+’ to the cursor and the component or group would be copied when moved. If I would let go of the CTRL-key, it would just act as a normal ‘move’.
Now, with the update, it seems that I first have to press the CTRL-key, let the key go, then the cursor adds a little ‘+’. After copy+moving the group or component the ‘+’ stays. I have to press&release CTRL again to go out of this mode.
In polite terms, this is extremely annoying. I loved that just by pressing M+CTRL I could ‘copy’ components and not worry about it once I released the CTRL-key. But now I’ve copied more than I would like to, or not copied at all (because I’m used to keeping the CTRL pressed down whilst copy+moving objects). The logic of this also fails me. If it’s not broken, why fix it? And if this is a fix: How is this supposed to help my productivity or workflow? It comes across as more of a hassle.
Is there any way I can go back to the setup as it was with the older version? Or am I missing a setting that I have activated by accident?
I agree with you both here and this “toggle on, toggle off” requires an additional keystroke vs just holding cntrl for a split second to actually make one copy. This change is good if you wish to make several copies without having to continuously re-click the cntrl button, however, if you only want to make one copy and then move the copied item straight away, you have to “toggle off” by clicking the cntrl.
I am also becoming increasingly irritated by the change here. It’s great to have the stamp option built in to the move/copy command, but when I use the Ctrl/Shift/Alt behavior switch key for the material painter to switch to a material eyedropper, I now have to hold the Alt key. Holding Shift to change a selection switches back to normal when I rotate the view to a new position, something I need to do a lot when in a modeling mode.
I wonder if these are oversights or something done intentionally. I wish they always kept a “legacy behavior” option in the preferences, so yeah, new kids can just get used to it, while old dogs who’ve been doing this stuff since the software began don’t get frustrated at every new version.
