Hi, I cannot find a post on this exact issue although some are similar.
I have one component in my model, a single timber baton with dimensions set at 34mm x 34mm x 3700mm. In materials type is dimensional, standard length is 2400mm, standard cross section is 34mm x 34mm.
When I run report in Open Cut List to generate a summary of the weight and cost of the raw materials I get this error:
No placement possible (trim size too large, standard panel too small, saw kerf too large, …).
Hoping someone may have had a similar issue and point me to what I am doing wrong.
Thanks for that, very much appreciated. Totally get it, I need a different supplier or I need to create the correct component size ie. max length 2.4m. Have to say what a superb piece of software engineering you have created with OpenCutList.
