Hi, I have a question in opencutlist.
my standard panel size is 2800 x 2070mm.
but i have to create a area of 2980 x 2490mm. which means more than the panel size.
If I create my area as a single component, is there any way to get the cutting list and diagram?
because it’s showing no placement possible. I attached the image here.
How would you join the sheets to make the area? two @ 249x149.1? or at partition placement? Grain?
two @ 249x149.1
seem that OCL does not give this as an option
@boris.beaulant
so only way is divide the sheet in two panels as per real life on the model, probably better as sometimes grain and partitions can be worked in
