I have watched numerous videos to see if I have done something wrong - no luck.
I have searched the problem on the internet - no results.
When I select multiple edges, the offset tool deselects them for some reason. enter image description here
The blue curves are the edges I’m trying to select.
But when I click on the offset button, it deselects them.
I’ve never had this problem before. EVER. But I haven’t used SketchUp in 6 months, so maybe I could be doing something wrong
DaveR
2
Most likely the curve doesn’t lie on a single plane. Offset only works with planar edges. Share the SKP file so we can see exactly what you’ve got.
Unfortunately, I’m having the problem with every other thing I select, except for things that are not flat on the ground.
DaveR
4
As I wrote, the edges must lie on the same plane for Offset to work.
Upload the SKP file so we can have a look.
Ok, so I have it fixed.
Apparently it was connected to another object in the file (meaning the line was attached to something else), which caused things to mess up.
Thanks anyway!
system
Closed
6
