See attached file. Right now a 2D shape, and I am trying to offset the edges. When I select an edge to offset, sometimes it offsets (just that one edge, not the whole shape) and sometimes it doesn’t (and there is a small circle with a line through it, indicating that it won’t apply the offset to the selected line).
What am I doing wrong? thanks –
You can’t offset just one edge with the ‘Offset’ tool in SketchUp. You’ll need to select at least two connected (or more coplanar connected) edges. Or a single face. The edges are needed to define the plane in which the offset will be taking place.
Also the offset only offsets from the outer loop of a face. The holes (inner loops) won’t accept an offset unless you fill them in with a face and then offset to their exteriors.
