Objects that are supposed to be covered by other objects appears incorrectly
Hi, i just found this issue:
I’ve modeled a chiar with 4 legs, this chiar must be seen in a 1:100 scale, so the profiles must be displayed correctly.
I wanna show that the legs are completly under the flat part of the chair, and everything in layout is displayed correctly.
But, if i move a leg out of the flat part, so the legs go under the curved part of the chair, part of the leg appears in layout, but it is supposed to be covered as the first position
The leg is under the flat part
Layout display the object correctly
If i put the leg out from the flat part
The issue appears
If you share the layout file it could be posible to guess what is happening.
Here is the layout file with another example
prova_componenti_1_100.layout (784.1 KB)
Those lines are in your SketchUp model too. You should hide them in SketchUp
Ok thanks, what about the others?
If you zoom in you see those lines. Try to smooth the face or reduce the mesh in that place. Active X-Ray to see it.
