Is it possible to change the axis for OBJ files in sketchup 2017?
As the export STL is not supported I exported as a 3d OBJ file, this was
rotated by 90 Deg when opened in Cura 2.3.0
You can rotate in Cura but this is very sensitive and seams to confuse Cura
ie: the build plate adhesion is incorrect when the print is rotated.
How can I change the axes to prevent this?
If there is no way of changing the axes I will have to revert back to SketchUp 2016.
Thanks,
Phil Sharrock
