No SketchUp Make 2017 "EXE", file
#1
I have used SketchUp for some time and I am using 2016 now. I am Color blind and 2017 is has a solution to that problem. But the Actual “SketchUp.exe” file is missing.
I have 64 system, Windows latest version of installer, NET Framework 4.5.2, and Visual C++ Redistributable for Visual Studio 2015.
#2
I have Removed and Reinstalled SketchUp Make 2017 and now have an “Sketchup.exe” file but it will not open.
#3
When you installed SketchUp 2017 from its installer exe file I suspect that you did NOT you do it in the proper way…
Select the installer’s exe file icon.
Right-click > context-menu
Run as administrator
This method will install SketchUp properly,
If SketchUp is already installed, then selecting the Repair option might fix thins, without the necessity of an uninstall/reinstall ?
Trying to install SketchUp by double-clicking its installer or just ‘run’ will NOT work - it MUST be done in the recommended [only] way !
#4
I have the EXE file now, but when I click it, the load Icon shows up and
then after a few seconds disappears.
I can't get SketchUp Make 2017
#5
Usually caused by either graphics card that is too old (and does not support OpenGL v3,) or an out of date graphics driver.
See this help post: 2017 not launching
P.S. - @LowellB
#6
It’s probably the Card this is an old Computer. Thank you very much, I was
just surprised because the 2016 version works just fine.
I thank you for your help and advice.
Lowell
