Usually, when an entire object is set to a single color, such as white, certain sides of the object appear as gray depending on the perspective you are viewing it from. However, when I opened up my model today, all objects appear seamlessly as a single color. The shading appears to be completely gone, making certain objects much harder to see. Example below.
I’m still a newbie to Sketchup, so I don’t know where I can change the settings for this or if there even are any. I have had the Face Style set to “Shaded with Textures” until now, and it has never given me this issue before. Any help would be greatly appreciated.
I would point out that if that fix worked, it probably means you had the Dark slider value set too high in the Shadows panel. That will wash out the shadows.
