Floor plan V1.skp (35.4 KB)
I don’t see anything skewed in your model. The camera has been orbited a little off of looking straight down and you have it set to Perspective. If you’d leave the model axes displayed you could ident ify that. Note how the red axis is not parallel to the bottom of the model window and the vertical blue axis is visible.
If you set the Camera to Parallel Projection and choose the Standard Top view, the axies and the model will align with the edges of the model window.
Set that up and create a scene for that camera position. It’s generally best to do your modeling with the Camera set to Perspective but for a plan view like this, you’ll want the Camera set to Parallel Projection.
Thank you so very much. Ah ok, i wasnt even aware that it was set to Perspective, this is a new learning for me and problem sorted out. Im truly grateful to you. Thanks a ton…
It would help you to leave the axes turned on so you have them as a clue. Also take the time to go through the educational materials at learn.sketchup.com
Thank you so much Dave for taking time to reply
I really do need to learn the system or do a course as I feel im missing out on most of the features.
Thanks for you advice.
Appreciated
