New Sketchup user here Help with model
Hi, I’m trying to model a stand picture enclosed.
The vertical edges are at different heights, I can’t seem to close the top face.
Can someone let me know how this is done?
many thanks
If the top face won’t close when you redraw one of the edges, it is because the corners aren’t on the same plane. I would make first the vertical faces all higher than needed, then add a larger face at the right height with the right inclination and then use the Intersect command to combine them and then trim off the excess. Another way is to close the top first by drawing triangles and then moving some of the corners to lie on the same plane, and finally remove the triangle edges,
Thanks but I don’t get it, too technical.
mod-02
https://learn.sketchup.com/track/sketchup-fundamentals-part-1
@mihai.s Thank you very much I highly appreciate your expertise. :slight_smile:
