Negative Shadows.
Shadows on flor disabled.
Any idea?
Shadows on ground - on?
Iâm not sure what kind of fix you need for what kind of problemâŚ
In the sample below you can see the two types of shadow castings and their effect:
recap:
Surface = every area diagonal, horizontal and vertical below and/or above level Z=0
Ground = only horizontal area at z=0 height
One could say the âsurface shadowâ is the most realistic, and you could disable the âground shadowâ.
Be sure you disable this before making scenes, otherwise you might need to edit multiple scenes/shadow settings, as i learned the hard way
Iâve found the problem. It was really easy: the volume with ânegative shadowsâ had double faces.
Once I erased the âextraâ faces the shadows turned ok.
The volume was duplicated.
Thankyou.
