How do I make a tapered pole with a curved, see attached drawing. Using Sketchup Pro 2020! See picture below
curved pole|381x500
You could make a straight tapered “pole” and use Radial Bend in Fredo6’s FredoScale tools to bend it where you need it. Or since you have a centerline and the circles at each end, you could use Fredo6’s Curviloft to create it. Both extensions are available from Sketchucation.
does that extension work in SU 2020?
ok yep ![]()
Extension Warhouse search is not finding it.
I will look
Is CLF Shape Bender working with 2020?
again thanks
It worked really well. Downloaded Fredo6’s fredocorner, too. Good for chamfering corners.
