I’ve imported an STL file into Sketchup 2017 Make, and it’s not behaving like I expect. The model is of an object I’m trying to print on my 3D printer. The problem is that my printer tends to make holes slightly smaller than they should be, so if I need an exact fit, I have to make them slightly larger in the model. However, in this case, the model is something that I didn’t design myself, so I’m trying to make the holes larger after-the-fact.
I know how to use push/pull to make a hole from a circle. I also know to use Intersect Faces → With Selection in order to properly “carve out” the whole from an irregular surface. But this technique is not working for me.
The model is here: Makamaka_left_end_I2.skp (208.1 KB)
Here’s a view of the semi-hole that I’m trying to widen. You can see the circle at the bottom.
My idea is to extrude the circle into a cylinder until it touches the opposite side, and Intersect it with the model, and then delete the cyclinder, like this:
The problem is that no matter what I do, I can’t delete the cylinder without screwing up the rest of the model. I’ve been trying all sorts of things for the past hour and I’m befuddled.
