My Sketchup Pro 2014 for Mac won't run unless I upgrade
I tried to run my Sketchup Pro 2014. It pops up a window saying a newer version is available and has a button to click to download. But I can’t close the window and just continue running Sketchup 2014. Do I have to upgrade? what if I want to continue using my Sketchup 2014?
Thanks,
Brita van Rossum
I’m having the same problem - so frustrating! Even more so as I had the same issue a couple months ago and got it resolved but can’t remember or find what I did to make it work. Pretty sure it was via tech support but it’s now the weekend and I can’t get anything done.
If you find a solution, please post as will I.
I am also have the same problem… I even re-downloaded Sketchup Pro 2014 from the download page and it still tells me it’s expired. 2015 doesn’t work on my computer because it’s not compatible. I sent an email to support so I’ll post if I get a helpful response. Please let me know if you find a solution.
I found this searching SketchUp help but it doesn’t seem to apply.
I’m in the same boat as I can’t run 2015. Also reinstalled SU2014 to no avail. I’m on a Mac and tried trashing preferences files as suggested elsewhere on this forum which also did not work.
I am having the same problem running MAC OS X 7.5, so need Sketchup Pro 2014 but keep getting a message that my version has expired, reinstalling seems to have no affect.
I’m trying to recall the posted solution, I think it was…
close SU…
disconnect from internet…
open SU…
reconnect to internet…
I think it resets something, but can’t remember what…
It was on this forum 16/17th March, but where is the search field???
I disconnected from the internet and opened up my file - it works fine. I kept the file open and turned on the wifi and it worked fine still. So then I turned SketchUp back off, turned on the wifi, and opened the file again. It doesn’t work and the pop up window is back.
I suppose the temporary solution would be to disconnect from the internet and use it. Hopefully there is a more permanent solution though.
Thank You! Yes that works for now - at least I can get some work done!
yes i think there is one more step, but my memory is blank…
john
Thank you! Let us know if you remember
top-right
@Jeff
cheers for that, but it cant find any posts containing the message ‘Your current version has been expired’
I try other key words…
john
heh, yeah.
I’m not having much luck with it either :confused:
What about opening the Preferences dialog, going to the General tab, and unchecking the “Automatically check for updates” option ?
I always do this in all older SketchUp versions, after I install the newest major version. (I keep at least the last 3 versions installed for testing plugins.)
Repeatedly Telling me to Update to a New Version
I contacted SketchUp Tech Support over the weekend about this as I tried to fond work arounds. Their response on Monday blamed the problem on a Saturday SketchUp 2014 bug which they fixed. It now works OK for me.
