My model disappeared from zoom extents, please help 🙏
Can someone help me with my model? I have tried everything you guys suggested from previous forums but it seems like it still would not work..
What model?
it appears like this and when i hit zoom selection/extents, it doesn’t do anything
We can´t do anything without the actual model.
i uploaded my model here: https://drive.google.com/file/d/1v-CBpen4tdpBXNIerlfmjvN9d8csM5Q-/view?usp=sharing
The problem is with a component named adminersFINAL-0. You can find that entity in the Outliner and delete it.
Those two components are causing that. I deleted them, selected everything from the outliner and pasted it on a new file. and this is what I see.
It´s better to work closer to the model origin, the court is like 300 meters away from the origin, that could cause some glitches.
Purging the file with CleanUp3 showed that there are a lot of unused stuff.
you have also some unnessesarily huge materials that you should resize.
And last but not least, you should pay attention to reversed faces, on monochrome style everything should look white, I set the back faces color to green so it can be noticeable on the screen shot.
Edit. I forgot to tell you to turn off profile edges, that generates a lot more load on your gpu, Length and angle snapping should in most of the cases be disabled as well, it can cause some accuracy mistakes.
thank you so much! this helps a lot!!
