Below is the file, Please fix it.
It opens for me on sketchup 2025, you can update from 2023 to 2025 without extra payment, unless you’re using a cr cked version of course.
You should do a clean up to your model, there are a lot of heavy components I guess from the 3DWH with unnecessary detail, some of those components have their own tags, hence you have tags in 3 different languages, also having profile edges active, doesn´t help your gpu. If you let run cleanup 3 plugin it will take a long time to do its job.
Please can you send me the fixed file for me sir.
I haven´t fixed your file, I tried to run cleanup 3 but it is taking a lot of time, i forced the quit and tried the native purge but it crashed, just install sketchup 2025 as administrator and you’ll be able to open the file, sketchup 2025 has a feature that detects corrupted components and deletes from your file.
There are a lot of threads that show you how to fix your file and reduce its size for up to 90%
Please sir I had no time.My project submission is on 1 day. Please help me sir.
I told you the solution, the file I would send is the same you sent, just install sketchup 2025 and you will be able to open your file.
I´ll wil run cleanup 3 while i work on my project and check in a while to see if it was cleaned or the file crashed, if its done i will sen that file.
Thank you sir hope it will fix when you cleanup the file.
It´s been over 40 mins and it´s still running the cleanup. It´s 00:05 am here and I´m very tired, after a long day of work, you should download sketchup 2025 install clean up 3 and let it run overnight.
Thank you sir for your advise.But I can’t download sketchup 2025 version.Is there are any alternative.
Please anybody help me.
Why? I don´t know any other solution, probably start over keeping the file clean, dont use models from the 3DWH.
You should take a look at the free courses on sketchup campus when you have time.
https://learn.sketchup.com/
Why can’t you download sketchup 2025? If you have a license that lets you use Sketchup 2023, you can use Sketchup 2025 without any extra cost.
Are you using a cr cked version of sketchup?
Yeah it was my friends file who was trouble with this file.
Please help me sir.
He has. The file opens in sketchup 2015. It’s included in your subscription. Just get 2025…
Please anyone help me and send me fixed file for me.
just install 25, connect with your account, and it’ll open right away. save and it’ll prompt you to purge.
2/3 of the file is trash.
also, any reason why your file didn’t have an extension ?
it’s sketchup file when it should be sketchup file.skp
these 4 potted mint plants represent 0,5 million entities. for four plants on a bedside table.
that’s 15% of your file in these 4 plants.
Can you please do purge for me and I want file sir please
You’re using a cr cked version, you’re looking for help in the wrong place.
Please help me anybody I need fixed file.
