MS Physic problems
I installed MS Physic and the required Library from SketchUcation but I get a window listing errors at SketchUp start-uo. See below:
Erreur de chargement du fichier /Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb
Error: #<IOError: The required, staged c extension file, “/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/ams_Lib/libraries/stage/osx64/2.7/ams_lib.bundle”, is missing!>
/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in `block in require_all’
/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `each’
/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `require_all’
/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb:148:in `<top (required)>’
/Applications/SketchUp 2021/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.7.1/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in `require’
/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb:7:in `<top (required)>’
/Applications/SketchUp 2021/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require’
/Applications/SketchUp 2021/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load’
/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in `register_extension’
/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in `module:MSPhysics’
/Users/jlemire/Library/Application Support/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:5:in `<top (required)>’
I wonder what is going on.
I am using SU 2021 latest version for Mac, running on OS Catalina 10.15.7 in French canadian.
Hello / Bonjour.
Sauf erreur de ma part, MS Physic est pour sketchup 2018 et inférieur.
Jean, the following id from early 2019. Anton has reported that he is working on an updated version but it hasn’t been released yet. I understand he’s occupied with paying work which has to take priority.
https://sketchucation.com/forums/viewtopic.php?f=61&t=70879
Thanks Dave, I should have read the full thread on SketchUcation.
I copied the files from the 2021’s Plugins folder to the 2017’s Plugins folder and it seems to work OK.
I still have to see if 2017 plays nice with Catalina.
Merci Paul, effectivement MSPhysic semble fonctionner avec SU 2017. Je vais essayer avec 2018.
Je vais aussi vérifier si SU 2017 et 2018 fonctionnent avec Catalina.
