Hi, whenever I first open up SU I get an error message, any ideas what a fox might be? Here’s a c&p of the error messaage:
Error Loading File C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
Error: #<IOError: The required, staged c extension file, “C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.5/ams_lib.so”, is missing!>
C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:199:in block in require_all' C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in each’
C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in require_all' C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/main.rb:129:in <top (required)>’
C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require’
C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:7:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require’
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension’
C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/pavel/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>’
Thanks
Box
January 5, 2020, 12:08am
2
MsPhysics doesn’t work with 2019 so remove it.
tt_su
January 6, 2020, 3:23pm
3
With sketchup 2020 not work!
Only with sketchup 2018 do it.
Thanks
MSPhysics works well with SketchUP 2019. use AMS library and move the MSPhysics directory and MSPhysics.rb manually in the C:\Program Files\SketchUp\SketchUp 2019\ShippedExtensions\ directory
Hi! Unfortunately, it does not work.
abba
October 26, 2021, 2:40pm
8
Did it work?
EDIT: Just tried it myself on the 2021 version, nope:
Error Loading File C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb
Error: #<IOError: The required, staged c extension file, "C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.7/ams_lib.so", is missing!>
C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:199:in `block in require_all'
C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in `each'
C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in `require_all'
C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb:129:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in `require'
C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb:7:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `load'
C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in `register_extension'
C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in `<module:MSPhysics>'
C:/Users/Growlithe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:5:in `<top (required)>'
