Load Error on MSPhysics
MSPhysics no worky.
Me sad.
Got extension from right here.
Where did I go wrong? :frowning:
Error Loading File C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb
Error: #<IOError: The required, staged c extension file, "C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.7/msp_lib.so", is missing!>
C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:219:in `block in require_all'
C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in `each'
C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in `require_all'
C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main.rb:70:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in `require'
C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `load'
C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in `register_extension'
C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in `<module:MSPhysics>'
C:/Users/Braden/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:5:in `<top (required)>'
[/details]
Maybe expecting it to work in SketchUp 2021. It doesn’t.
:no_mouth:
Not cool. I guess the only way to access it is by using an older version.
The last version it works in is SU2018. The author is working on a newer version.
Thanks for the info Dave. I’ll keep an eye out.
A minor correction, you’ve gone back a few versions too many, 2018 definitely, perhaps even 2019 but I’m not sure on that.
Thanks. Typing in the dark. Fixt.
