Mouse trouble (MX Master 3s) on Pro using Mac
Can anyone help with troubleshooting my mouse on pro? I upgraded from the web version to pro recently, and took a serious step down in the use of my mouse. I can’t get the thumb wheel to respond in the pro version. It works great on the free version. I am on a Mac (Sequoia), running the new Pro version of sketchup, and have a MX master 3s for mac. I have tried restarting, resetting defaults on the mouse, and checking forums, but not getting it to work yet. I also checked to see if sketchup was installed more than once, but only seeing one copy. The logi tech screen indicates that I should have horizontal scroll in sketchup, but no luck.
SketchUp isn’t officially supported in Sequoia yet - so it could be something is broken…
I haven’t used a Logitech in a long time - do you have the latest configuration software installed?
If you use a ‘dumb’ mouse (or a Magic Mouse) does orbit work as expected?
Logi is up to date. I did reach out to them to get their idea on addressing this issue. I don’t have a magic mouse- it was between the two when buying and it seemed from reviews that the mx had more versatility for design programs.
I have the same mouse and it works fine with SU 2024 on Sequoia. I can think of two possible explanations for issues you may be having:
  • Wrong expectations. For example, the horizontal scroll wheel in the desktop version doesn’t do the same thing as in the web version. It has to do with how SketchUp desktop reacts to the mouse events sent by that device vs the way the web browser does. The desktop does not by default even react to the horizontal scroll.
  • The settings for the mouse may need to be tweaked. You can use Logitech Options+ for this. SketchUp by default expects a pretty basic 3-button mouse with center scroll wheel. If you have special settings, they may not be right for SU.
Understand. Maybe I thought that the Pro version would do as much or more than the free version. Disappointing to shell out the $$ for pro and not be able to use the thumbwheel (yet).
What would you like it to do? If enough other people share your wish, it would make a reasonable feature request. But since most mice don’t have a horizontal scroll wheel, it might get low priority.
I have the same issue with MX Master 3 and experienced the same disappointment switching from free to pro. The thumbwheel is set to zoom in and out in every application on my Mac and it is just annoying that Sketchup Pro should be the one app where this does not work.
After trying for 1/4 of my annual license period and reaching out again, sketchup got around to doing something besides ‘check the forum’. They sent a link with instructions to uninstall the pro version and download a different version (Offline Download | SketchUp | SketchUp). The second one is more functional, but still does not utilize the mx master 3s (which works flawlessly on the free version). Their official line was, “It looks like some other users in the forum are experiencing issues with this mouse and macOS Sequoia. As this operating system is not supported we are limited in how we can assist you besides advising a reinstall of the software. It may be worth posting to the form to see if other users have come up with a solution for this issue”
It would be nice, when purchasing the software, to know that the Mac OS is ‘not supported’, even though they feature a mac download. I will be looking into other design software in the future for sure.
Yeah, ummm, macOS is supported, but Sequoia came out after 2024 was released, and it clearly says here:
I would bet money that 2025 will support Sequoia … so if you stick with SketchUp because yes, macOS is supported - be sure NOT to update your OS until you know the software you use works…
The central wheel allows for Zoom in / Zoom out when you roll the wheel.
You can orbit if you press that wheel down.
Add the Shift key while pressing the wheel down to pan.
I have no problem using my MX Master 3 with sketchUp on my Macbook Pro (2017 model running Ventura 13.7.3).
I have a SIMILAR issue. I used version 8 on Windows for many, many years. Recently moved to a Mac and SU Pro for Mac. On my windows machine I had a mouse with wheel. I could EASILY enter Orbit mode by pressing this wheel. Now my Mac system has the Apple mouse that came with it. No wheel. Does there exist an equally easy way to enter Orbit mode that doesn’t involve going to the menu bar and clicking the Orbit icon?
I only work with trackpad on my Macs, and so have the same need. You can press control-command to temporarily go into Orbit mode. Once you are in that mode you don’t have to keep the keys held down, and you can press or release shift to go in and out of Pan.
